关键词:电源管理 DC/DC转换器 锂电池充电器 MB39A134
时间:2017-01-11 09:54:32 作者:Cypress 来源:中电网
cypress公司的MB39A134是用于锂电池充电的DC/DC转换器,采用脉宽调制(PWM)来单独控制充电电压和充电电流.器件内置独立于 DC/DC 转换器控制部分的 AC 适配器检测比较器,可控制系统的电压供给源,支持 2, 3 和 4Cell 电池包.主要用在笔记本电脑等的内置充电器和便携式终端机等.本文介绍了MB39A134主要特性,框图和应用电路及其所用元件列表,以及基于LPC MCU MB95F223K和MB39A134, MB95F223K的F²MC - 8FX锂电池充电器硬件框图,电路图,材料清单和PCB设计图.
The MB39A134 is a DC/DC converter IC for charging Li-ion battery, which is suitable for down conversion, and uses pulse widthmodulation (PWM) for controlling the charge voltage and current independently.
MB39A134 has a AC adapter detection comparator independent of the DC/DC converter controller, and can control the source ofpower supply to a system. It supports a wide input voltage range, enables low current consumption in standby mode, and cancontrol the charge voltage and charge current with high precision, which is perfect for the built-in Li-ion battery charger used indevices such as notebook PC.
MB39A134主要特性:
• Support 2, 3 and 4 Cell Battery Pack
• Built-in two constant current control loops
..分享到:
