[原创] ST TN5050H-12WY汽车级50A 1200V可控硅解决方案
关键词:电源管理 可控硅 SCR TN5050H-12WY
时间:2016-09-26 09:48:22       作者:ST       来源:中电网
ST公司的TN5050H-12WY是汽车级50A 1200V可控硅(SCR)器件,采用大功率TO-247封装,耐压1200V,导通电流50A rms,具有高的静态和动态转换:dI/dt = 200 A/μs;dV/dt = 1000 V/μs,主要用在汽车充电,可再生能源,不间断电源(UPS),固态继电器,焊接设备和马达驱动等.本文介绍了TN5050H-12WY主要特性,评估板STEVAL-ISF003V1主要特性,功能框图,电路图,材料清单和PCB元件布局图.
Available in TO-247 high power package, theTN5050H-12WY autograde is suitable in applications such as automotive / stationarybattery charger, renewable energy generator, interruptible power supply, solid state relay,welding equipment and motor drive applications.
Its power switching, voltage robustness andpower dissipation performances are the key features for functions such as a 80 A AC switch,an AC phasing inverter and an AC-DC controlledrectifier bridge.
The TN5050H-12WY is an automotive gradeproduct and offers a superior performance in surge current handling, thermal coolingcapabilities and overvoltage robustness
TN5050H-12WY主要特性:
• On-state current: 50 Arms
• Blocking voltage: 1200 V
• High static and dynamic commutation:
– dI/dt = 200 A/μs
– dV/dt = 1000 V/μs
• AEC-Q101
• IGT = 50 mA
• ECOPACK®2 compliant component
查看全文
