关键词:SmartFusion2 SoC FPGA 通信 医疗电子
时间:2016-07-12 11:03:02 作者:Microsemi 来源:中电网
Microsemi公司的SmartFusion2 SoC FPGA系列是提供多达90K逻辑单元,多达5MB嵌入RAM,多达4个SERDES通路,多达2个PCIe端点,集成了具有单误差修正和双误差检测的硬DDR3存储器控制器,并提供了带嵌入ARM® Cortex™-M3的低功耗实时MCU子系统(MSS),主要用通信,工业,医疗,国防和航空等市场.本文介绍了SmartFusion2 SoC FPGA系列主要特性和架构图,SmartFusion2安全评估板M2S090TS-EVAL-KIT主要特性,框图,电路图和材料清单,PCB元件布局图.
Microsemi®’s automotive grade SmartFusion®2 system-on-chip (SoC) field programmable gate array (FPGA) andIGLOO®2 FPGA families offer the best-in-class security, industry leading high reliability and lowest static power in aflash-based fabric. With a strong heritage of supplying to Military and Aviation customers, Microsemi automotive gradedevices are ideally suited to meet the demands of the automotive industry providing the lowest total-cost-of-ownership.
These next-generation devices integrate an industry standard 4-input lookup table-based (LUT) FPGA fabric withintegrated mathblocks, multiple embedded memory blocks, high-performance SERDES communications interfaces ona single chip with extended temperature support.
分享到:
