[原创] Linear LTC4282大电流100A热插拔控制方案
关键词:电源管理 热插拔 I2C LTC4282
时间:2016-02-18 10:21:54       作者:Linear       来源:中电网
Linear公司的LTC4282是大电流100A热插拔控制器,应用电压从2.9V到33V.采用一个或多个N沟通过晶体管,允许板从安全地插入和拔出带电的背板.器件包括12/16位ADC,误差±0.7%,采用I2C接口可监测电流,电压和功率与能量,内部的EEPROM用来非易失性配置,主要用在企业服务器和数据存储系统,网络路由器和交换,基站和平台管理.本文介绍了LTC4282主要特性,框图,几种应用电路,以及演示板DC2024A主要特性,电路图,材料清单和PCB元件布局图.
The LTC.4282 Hot Swap™ controller allows a board tobe safely inserted and removed from a live backplane.Using one or more external N-channel pass transistors,board supply voltage and inrush current are ramped upat an adjustable rate. An I2C interface and onboard ADCallows for monitoring of board current, voltage, power,energy and fault status.
The device features analog foldback current limiting andsupply monitoring for applications from 2.9V to 33V.
Dual 12V gate drive allows high power applications toeither share safe operating area across parallel MOSFETsor support a 2-stage start-up that first charges the loadcapacitance followed by enabling a low on-resistancepath to the load.
查看全文
