[原创] Infineon TLE9266QX汽车系统基础芯片(SBC)解决方案
关键词:汽车电子 系统基础芯片(SBC) CAN LIN TLE9266QX
时间:2016-01-27 14:07:40       作者:Infineon       来源:中电网
Infineon公司的TLE9266QX是用于CAN/LIN汽车车体应用的系统基础芯片(SBC),提供用于微控制器(MCU)电源的5V低压降稳压器,用于传感器电源的带短路保护的5V低压降稳压器,用于数据传输的HS-CAN收发器和LIN收发器,提供保护功能低和高边开关,用来控制和监视设备的16位SPI.本文介绍了TLE9266QX主要特性和优势,框图,简化应用框图及其材料清单,SBC驱动器评估板主要特性,电路图和PCB设计图.
The TLE9266QX is a monolithic integrated circuit in an exposed pad VQFN-48 (7mm x 7mm) power package. Thedevice is designed for various CAN-LIN automotive body applications as a main supply for the microcontroller andas an interface for a CAN and LIN bus networkTo support these applications, the System Basis Chip (SBC) provides the main functions, such as a 5V lowdropoutvoltage regulator (LDO) for microcontroller supply, a 5V low-dropout voltage regulator with short circuitprotection against supply voltage VS for e.g. sensor supply, HS-CAN transceiver and LIN transceiver for datatransmission, Low- and High-Side switches providing protective functions, and a 16-bit Serial Peripheral Interface(SPI) to control and monitor the device. Also implemented are a Window Watchdog circuit with a reset feature, aFail Output and an under voltage reset feature.The device offers low-power modes in order to support applications that are permanently connected to the battery...
查看全文
