TI TMS320F2837xS伺服和AC逆变器驱动参考设计
关键词:工业控制 伺服驱动器 逆变器 数字电源 太阳能微逆变器 智能测量
时间:2015-12-02 11:27:18       作者:TI        来源:中电网
TI公司的Delfino TMS320F2837xS是功能强大的用于闭环控制的32位浮点微控制器(MCU),工作频率200MHz,主要用在工业驱动和伺服马达控制,太阳能逆变器和转换器,数字电源,汽车交通,动力线通信,智能测量和雷达.本文介绍了Delfino TMS320F2837xS主要特性,框图,以及工业伺服和AC逆变器驱动参考设计TIDM-SERVODRIVE主要特性,框图,电路图,材料清单和PCB设计图.
TIDM-SERVODRIVE Industrial Servo Drive and AC Inverter Drive Reference Design Board Top View
The Delfino TMS320F2837xS is a powerful 32-bit floating-point microcontroller unit (MCU) designed for advanced closed-loop control applications such as industrial drives and servo motor control; solar inverters and converters; digital power; transportation; and power line communications. Complete development packages for digital power and industrial drives are available as part of the powerSUITE and DesignDRIVE initiatives.
The real-time control subsystem is based on TI’s 32-bit C28x floating-point CPU, which provides 200 MHz of signal processing performance. The C28x CPU is further boosted by the new TMU accelerator, which enables fast execution of algorithms with trigonometric operations common in transforms and torque loop calculations; and the VCU accelerator, which reduces the time for complex math operations common in encoded applications.
查看全文
