[原创] TI WL18xxMODWiLink2.4GHz模块双天线解决方案
关键词:无线通信 Wi-Fi Bluetooth 蓝牙BLE
时间:2015-11-02 09:47:54       作者:TI       来源:中电网
TI公司的WL18xxMOD WiLink™ 8单频段Combo模块,包括Wi-Fi,蓝牙和蓝牙低功耗(BLE),可提供高数据吞吐量和扩展范围,并支持Wi-Fi和蓝牙共存, 工作频率2.4GHz,双天线解决方案.器件经FCC, IC ,ETSI/CE,和 TELEC认证,适用于接入点 (AP) 和客户端,主要用在物联网(IOT),工业和家庭自动化,多媒体,智能网关和计量,家用电器和电子,视频会议,摄像机.本文介绍了WL18xxMOD主要特性,框图,典型应用-WL1835MOD参考设计及其材料清单,WiLink 1835模块天线参考设计主要特性,电路图,材料清单和PCB设计文件.
WL18xxMOD WiLink™ 8 Single-Band Combo Module –Wi-Fi®,Bluetooth ®,and BluetoothLow Energy (BLE).The certified WiLink 8 module from TI offers high throughput and extended range along with Wi-Fi andBluetooth coexistence (WL1835MOD only) in a power-optimized design. The WL18x5MOD device is a2.4-GHz module, two antenna solution. The device is FCC, IC, ETSI/CE, and TELEC certified for AP andclient. TI offers drivers for high-level operating systems such as Linux®, Android™, WinCE, and RTOS.
WL18xxMOD主要特性:
WL18xxMOD应用:
• Internet of Things
• Industrial and Home Automation
• Multimedia
• Smart Gateway and Metering
• Home Electronics
• Video Conferencing
• Home Appliances and White Goods
• Video Camera and Security
图1.WL1835功能框图..
查看全文
