关键词:ARM Cortex-M0 SOC MCU PSoC 4 马达控制
时间:2015-09-30 11:30:57 作者:Cypress 来源:中电网
Cypress公司的PSoC 4200M是业界最低功耗的基于32位ARM® Cortex®-M0核的系统级芯片(SoC),集成了模拟和数字IC,提供多达128KB闪存和55个GPIO以及包括RTC,CAN,DMA在内的外设,支持AEC-Q100标准以降低系统BOM成本和缩短产品开发时间.本文介绍了PSoC 4200M主要特性,框图以及PSoC 4马达控制评估板CY8CKIT-037主要特性,框图,电路图,材料清单和PCB设计图.
PSoC® 4 is a scalable and reconfigurable platform architecture for a family of programmable embedded system controllers with anARM® Cortex™-M0 CPU. It combines programmable and reconfigurable analog and digital blocks with flexible automatic routing. ThePSoC 4200M product family, based on this platform architecture, is a combination of a microcontroller with digital programmable logic,programmable analog, programmable interconnect, high-performance analog-to-digital conversion, opamps with comparator mode,and standard communication and timing peripherals. The PSoC 4200M products will be fully compatible with members of the PSoC 4platform for new applications and design needs. The programmable analog and digital subsystems allow flexibility and in-field tuningof the design.
The PSoC 4200-M devices include extensive support forprogramming, testing, debugging, and tracing both hardwareand firmware.
分享到:
