关键词:电源管理 电池充电器 DC/DC转换器 LTC4020
时间:2015-09-10 11:00:17 作者:Linear 来源:中电网
Linear公司的LTC4020是高压大功率电源管理器,提供PowerPath™即时运作和各种电压的高效率电池充电,输入电压4.5V-55V,输出电压高达55V(最大60V),浮充电压精度±0.5% ,充电电流精度±5%,主要用于手持工业和医疗设备,太阳能供电系统,军用通信设备和12V-24V嵌入式汽车系统.本文介绍了LTC4020特性,DC/DC控制器框图和充电器框图,几种典型应用电路,以及演示板DC2134A主要指标,电路图和材料清单.
The LTCR4020 is a high voltage power manager providingPowerPath™ instant-on operation and high efficiencybattery charging over a wide voltage range. An onboard buck-boost DC/DC controller operates with battery and/orsystem voltages above, below, or equal to the input voltage.
The LTC4020 seamlessly manages power distributionbetween battery and converter outputs in response to loadvariations, battery charge requirements and input powersupply limitations.
The LTC4020 battery charger can provide a constant-current/constant-voltage charge algorithm (CC/CV), constantcurrentcharging (CC), or charging with an optimized 4-step,3-stage lead-acid battery charge profile. Maximum converterand battery charge currents are resistor programmable.
分享到:
