关键词:ARM Cortex-M0 MCU 电动自行车 马达控制 LED照明 电动工具 XMC1000系列
时间:2015-08-26 11:41:08 作者:Infineon 来源:中电网
Infineon公司的XMC1000系列是基于ARM® Cortex®-M0内核的32位工业MCU,采用一流的65nm技术,集成了不同的外设,设计用于通用应用如电动自行车,LED照明,电动工具,风扇和看门狗等.本文介绍了XMC1000系列主要特性,框图,以及评估板XMC 2Go主要特性,框图,电路图和材料清单以及PCB设计图.
The XMC1100 devices are members of the XMC1000 family of microcontrollers based on the ARM Cortex-M0 processor core. The XMC1100 series devices are designed for general purpose applications.
XMC1000 microcontrollers bring together the ARM® Cortex®-M0 core and market proven and differentiating peripherals in a leading-edge 65nm manufacturing process. XMC1000 is the number one choice to bring traditional 8-bit designs to the next level.
XMC1000系列主要特性:
CPU Subsystem
• CPU Core
– High Performance 32-bit ARM Cortex-M0 CPU
– Most of 16-bit Thumb instruction set
– Subset of 32-bit Thumb2 instruction set
– High code density with 32-bit performance
– Single cycle 32-bit hardware multiplier
– System timer (SysTick) for Operating System support
– Ultra low power consumption
• Nested Vectored Interrupt Controller (NVIC)
• Event Request Unit (ERU) for programmable processing of external and internalservice requests..
分享到:
