PP3DP公司的3D智能打印机UP Plus 2,是最简单的桌面3D打印机,也是第一个配备全套平台自动校准系统,包括平台调平校准,平台高度校准。本文介绍了UP Plus 2 3D打印机,结构,物理特性和指标。
The UP! Printer is designed with ultimate portability and simplicity in mind. The system and software allow you to print great models with only a few keystrokes, even if you have never used a 3D printer before. The system uses a nozzle to deposit molten plastic, so printed parts are strong and durableCongratulationson purchasing an UP! Printer.
图1。UP Plus 2 3D打印机外形图
图2。UP Plus 2 3D打印机结构图
(1) Pedestal
(2) Platform
(3) Nozzle
(4) Extruder Guard
(5) Filament Tube
(6) Roller Shaft
(7) Material Filament
(8) Pilot Lamp
(9) Initialize Button
(10) Platform Level Calibration Device
(11) Nozzle Height Detect Device
(12) 3.5mm cable
UP Plus 2 3D打印机物理特性:
UP Plus 2 3D打印机指标:
详情请见:
http://pp3dp.com/index.php?option=com_jdownloads&Itemid=92&view=finish&cid=8815&catid=3
up_plus_2_user_manual.pdf..
分享到:
