关键词:蓝牙模块v3.0 USB加密狗 M2M工业控制 数据采集 安防系统 移动健康健身
时间:2015-08-06 10:46:07 作者:ST 来源:中电网
ST公司的SPBT2632C1A是容易使用的蓝牙模块,和蓝牙v3.0兼容,具有尺寸小和多功能特色,包括有快速UART和16个通用I/O线,几个串口, 高达560 kbps传输速度,主要用在串联电缆替代,M2M工业控制,服务诊断,数据采集,安防系统,移动健康健身,传感器监视等.本文介绍了SPBT2632C1A主要特性,框图和硬件特性架构图,STEVAL-SPBT4ATV3 USB加密狗(Dongle)主要特性,电路图,材料清单和PCB元件布局图.
The SPBT2632C1A.AT2 is an easy to use Bluetooth module, compliant with Bluetooth v3.0.The module provides complete RF platform in a small form factor.
The SPBT2632C1A.AT2 enables electronic devices with wireless connectivity, not requiringany RF experience or expertise for integration into the final product. The SPBT2632C1A.AT2 module, being a certified solution, optimizes the time to market of the final application.
The module is designed for maximum performance in a minimal space including fast speedUART and 16 general purpose I/O lines, several serial interface options, and up to 560 kbpstransmission speed with SPP service active, 250 kbps with iAP service active.An optimized design allows the integration of a complete working Bluetooth modem,including antenna and LPO (low power oscillator), enabling low power mode capability in the minimum possible size.
分享到:
