ADI ADuCRF101无线风速和风向数据采集系统解决方案关键词:ARM Cortex-M3 MCU数据采集系统工业和家庭自动化健康和健身设备无线传感器远程医疗系统资产跟踪
时间:2015-2-15 09:50:47 来源:中电网
ADI公司的ADuCRF101是用于低功耗无线应用的全集成的数据采集解决方案,集成了12位ADC,低功耗ARM Cortex-M3处理器, 862 MHz 到928 MHz和431 MHz到464 MHz RF收发器,以及闪存/EE存储器.工作电压2.2 V-3.6 V,主要用在电池供电的无线传感器,远程医疗系统,资产跟踪,工业和家庭自动化,健康和健身设备以及安全系统.
ADI公司的ADuCRF101是用于低功耗无线应用的全集成的数据采集解决方案,集成了12位ADC,低功耗ARM® Cortex®-M3处理器, 862 MHz 到928 MHz和431 MHz到464 MHz RF收发器,以及闪存/EE存储器.工作电压2.2 V-3.6 V,主要用在电池供电的无线传感器, 远程医疗系统,资产跟踪, 工业和家庭自动化,健康和健身设备以及安全系统.本文介绍了ADuCRF101主要特性,功能框图, ADuCRF101评估板主要特性,电路图,材料清单和PCB元件布局图,以及无线风速和风向数据采集系统功能框图和ADuCRF101评估板测试建立图.
The ADuCRF101 is a fully integrated, data acquisition solution that is designed for low power, wireless applications. It features a 12-bit analog-to-digital converter (ADC), a low power ARM® Cortex®-M3 processor, a 862 MHz to 928 MHz and 431 MHz to 464 MHz RF transceiver, and Flash®/EE memory. The ADuCRF101 is packaged in a 9 mm × 9 mm LFCSP.
The data acquisition section consists of a 12-bit SAR ADC. The six inputs can be configured in single-ended or differential mode. When configured in single-ended mode, they can be used for ratiometric measurements on sensors that are powered, when required, from the internal low dropout regulator (LDO). An internal battery monitor channel and an on-chip tempera-ture sensor are also available.
This wireless data acquisition system is designed to operate in battery-powered applications where low power is critical. The device can be configured in normal operating mode or different low power modes under direct program control. In flexi mode, any peripheral can wake up the device and operate it. In hibernate mode, the internal wake-up timer remains active. In shutdown mode, only an external interrupt can wake up the device.
The ADuCRF101 integrates a low power ARM Cortex-M3 processor. It is a 32-bit RISC machine, offering up to 1.25 DMIPS peak performance. The ARM Cortex-M3 processor also has a flexible 14-channel direct memory access (DMA) controller that supports communication peripherals, serial peripheral interface (SPI), UART, and I2C. Also provided o...
