关键词:无线通信 IEEE 802.15.4 ZigBee 6LoWPAN 工业控制 医疗保健 消费类电子
时间:2015-01-08 13:39:40 作者:Atmel 来源:中电网
Atmel 公司的AT86RF233是富有特性极低功耗的单片2.4GHz无线收发器,接收器灵敏度-101dBm,可编程输出功率从-17dBm到+40dBm, 工作电压1.8V-3.6V,深度睡眠的功耗为0.02uA,主要用于 2.4GHz IEEE 802.15.4和ZigBee系统,RF4CE系统,能量收获系统,6LoWPAN系统,工业控制,住宅区和商业自动化,医疗保健,消费类电子和PC外设等.本文介绍了AT86RF233主要特性,方框图,基本和扩展特性应用电路,以及REB233-XPRO扩展板主要特性,框图,电路图,材料清单和 PCB设计图.
The Atmel AT86RF233 is a feature rich, extremely low-power 2.4GHz radio transceiver designed for industrial and consumer ZigBee/IEEE 802.15.4, RF4CE, 6LoWPAN, and high data rate 2.4GHz ISM band applications.
The AT86RF233 is a true SPI-to-antenna solution. All RF-critical components except the antenna, crystal, and de-coupling capacitors are integrated on-chip. MAC and AES hardware accelerators improve overall system power efficiency and timing. Therefore, the AT86RF233 is particularly suitable for applications like:
• 2.4GHz IEEE 802.15.4 and ZigBee systems
• RF4CE systems
• Energy Harvesting systems
• 6LoWPAN systems
• Wireless sensor networks
• Industrial Control
• Residential and commercial automation
• Health care
• Consumer electronics
• PC peripherals
AT86RF233主要特性:..
分享到:
