Freescale Kinetis KW2x USB软件包监听器解决方案
关键词:ARM Cortex-M4 MCU 消费类电子 工业控制 软件包监听器 软件狗
时间:2014-08-19 09:56:26       作者:Freescale       来源:中电网
Freescale公司的Kinetis KW2x系列是集成了2.4GHz RF的低功耗无线MCU,包括高性能2.4 GHz IEEE® 802.15.4兼容的无线收发器和具有连接与混合信号模拟外设的功能强大的基于ARM® Cortex®-M4核的MCU系统,主要用于消费类电子如开水控制器,遥控器, 活动与健康监测仪,工业控制,接入和遥控以及温度控制.本文介绍了Kinetis KW2x系列无线电特性和MCU特性,简化框图, USB软件包监听器/软件狗USB-KW24D512主要特性,框图,电路图,材料清单与PCB元件布局图和走线图.
The Kinetis KW2x MCU is a low power, compact integrated device consisting of a high-performance 2.4 GHz IEEE® 802.15.4 compliant radio transceiver and a powerful ARM® Cortex®-M4 core system with connectivity and precision mixed signal analog peripherals.
Part of the large Kinetis MCU portfolio, the Kinetis KW2x MCU family of devices are used to easily enable connectivity based on the IEEE 802.15.4 family of protocols including ZigBee Pro network stack and application profiles for smart energy 1.x, home automation, healthcare, and RF4CE, as well as the ZigBee IP network stack and the smart energy 2.0 application profile. Typical applications include home area networks consisting of meters, gateways, in-home displays, and connected appliances, and also networked building control and home automation applications with lighting control, HVAC and security.
查看全文
