Freescale MCF51MM256人体活动监视器参考设计
关键词:ColdFire V1 MCU 人体活动监视器计步器医疗电子可穿戴电子物联网
时间:2014-7-15 10:52:04      来源:中电网
Freescale公司的MCF51MM256是低成本低功耗高性能ColdFire V1系列32位MCU,工作频率高达50.33 MHz,主要用于手持计量设备.本文介绍了MCF51MM256主要特性,框图,以及人体活动监视器参考设计RDACTIVITYMONITOR主要特性,框图和应用示意图,电路图,材料清单和PCB外形图.
The MCF51MM256 series devices are members of the low-cost, low-power, high-performance ColdFire V1 family of 32-bit microcontrollers (MCUs) designed for handheld metering devices.
MCF51MM256主要特性:
32-Bit ColdFire V1 Central Processor Unit (CPU)
• Up to 50.33 MHz ColdFire CPU above 2.4 V and 40 MHz CPU above 2.1V and 20 MHz CPU above 1.8 V across temperature range of -40℃ to 105℃.
• ColdFire Instruction Set Revision C (ISA_C).
• 32-bit multiply and accumulate (MAC) supports signed or unsigned integer or signed fractional inputs.
On-Chip Memory
• 256 K Flash comprised of two independent 128 K flash arrays; read/program/erase over full operating voltage and temperature; allows interrupt processing while programming.
• 32 KB System Random-access memory (RAM).
• Security circuitry to prevent unauthorized access to RAM and
Flash contents.
Power-Saving Modes
• Two ultra-low power stop modes. Peripheral clock enable register can disable clocks to unused modules to reduce currents.
• Time of Day (TOD) — Ultra low-power 1/4 sec counter with up to 64 sec timeout.
• Ultra-low power external oscillator that can be used in stop modes to provide accurate clock source to the TOD. 6 μs typical wake up time from stop3 mode.
Clock Source Options
• Oscillator (XOSC1) — Loop-control Pierce oscillator; 32.768 kHz crystal or ceramic resonator dedicated for TOD operation.
• Oscillator (XOSC2) for high frequency crystal input for MCG reference to be used for system clock and USB operations.
• Multipurpose Clock Generator (MCG) — PLL and FLL; precision trimming of internal reference allows 0.2% resolution and typical...
  • 芯闻
  • 芯品
  • 文章
  • 时 间:2026年5月19日
