Infineon 1ED020I12-B2单路IGBT驱动解决方案
关键词:电源管理 IGBT 太阳能
时间:2014-06-30 15:17:27       作者:Infineon       来源:中电网
Infineon公司的1ED020I12-B2是电流隔离的单路IGBT驱动器,输出电流高达2A,所有的逻辑是不5V CMOS兼容的,能直接连接到微控制器,适用于600V/1200V IGBT,主要用在交流和无刷DC马达驱动,高压DC/DC转换器,UPS系统和焊接.本文介绍了1ED020I12-B2主要特性和产品亮点,框图,典型应用以及栅极驱动评估板EVAL_1ED020I12-B2主要特性,电路图,材料清单,PCB元件布局图和PCB走线图以及Infineon采用IGBT的太阳能电源和微逆变器解决方案.
The 1ED020I12-B2 is a galvanic isolateed single channel IGBT driver in PG-DSO-16-15 package that provides an output current capability of typically 2A.All logic pins are 5V CMOS compatible and could be directly connected to a microcontroller.
The data transfer across galvanic isolation is realized by the integrated Coreless Transformer Technology.
The 1ED020I12-B2 provides several protection features like IGBT desaturation protection, active Miller clamping and active shut down.
1ED020I12-B2主要特性:
• Single channel isolated IGBT Driver
• For 600V/1200 V IGBTs
• 2 A rail-to-rail output
• Vcesat-detection
• Active Miller Clamp
1ED020I12-B2产品亮点:
• Coreless transformer isolated driver
• Basic insulation according to DIN EN 60747-5-2
• Integrated protection features..
查看全文
