TI公司的F2803x系列产品采用C28x核和控制加速器(CLA),是高效率的32位CPU,工作频率60MHz,16x16和32x32MAC运算, 16x16双MAC,具有哈佛总线架构和快速中断响应和处理,工作电压3.3V,主要用在智能电网和动力线通信,白色家电,开关电源,DC/DC多输出电源, 太阳能微逆变器和转换器, 缝纫机和纺织机,功率因素修正以及AC/DC逆变器.本文介绍了F2803x 系列主要特性,框图, 太阳能微逆变器开发套件主要特性,连网/离网太阳能微逆变器框图,太阳能微逆变器系统框图,电器指标和详细电路图.
The F2803x Piccolo family of microcontrollers provides the power of the C28x core and Control Law Accelerator (CLA) coupled with highly integrated control peripherals in low pin-count devices. This family is code-compatible with previous C28x-based code, as well as providing a high level of analog integration.
An internal voltage regulator allows for single-rail operation. Enhancements have been made to the HRPWM module to allow for dual-edge control (frequency modulation). Analog comparators with internal 10-bit references have been added and can be routed directly to control the PWM outputs. The ADC converts from 0 to 3.3-V fixed full-scale range and supports ratio-metric VREFHI/VREFLO references. The ADC interface has been optimized for low overhead and latency.
F2803x 系列主要特性:
High-Efficiency 32-Bit CPU (TMS320C28x)
60 MHz (16.67-ns Cycle Time)
16 x 16 and 32 x 32 MAC Operations..
分享到:
