Freescale Kinetis KL1x MCU评估方案
关键词:消费类电子 手持设备
时间:2014-05-07 09:57:19       作者:Freescale       来源:中电网
Freescale公司的Kinetis KL1x MCU系列产品采用32位ARM Cortex-M0+内核,有多达256KB闪存和多达32KB RAM.器件具有超低功耗,并和基于ARM® CortexTM-M4核的Kinetis K10 MCU系列兼容. Kinetis KL1x MCU系列具有丰富的模拟,通信,计时和控制外设,主要用在低功耗应用,以电池为能源的设备,USB外设和消费类电子产品.本文介绍了Kinetis KL1x MCU系列产品主要特性,框图,以及评估板FRDM-KL25Z主要特性,框图和电路图.
The Kinetis KL1x MCU family is pin, software and tool compatible with all other Kinetis L families, and provides additional memory, communications and analog peripheral options beyond those offered on the KL0x family. The Kinetis KL1x MCU family is also compatible with the Kinetis K10 family of MCUs built on the ARM® CortexTM-M4 core, providing a migration path to higher performance and feature integration. Devices start from 32 KB of flash in a small-footprint 5 x 5 mm 32 QFN package, extending up to 256 KB in a 80 LQFP package. Each family member combines ultra-low-power performance with a rich suite of analog, communication, timing and control peripherals.
Kinetis KL1x MCU主要特性:
Ultra Low Power..
查看全文
