Altera Stratix V DSP开发方案
关键词:通信技术 以太网 光纤通信
时间:2014-04-28 10:16:21       作者:Altera       来源:中电网
Altera公司的Stratix V FPGA是采用28nm技术,在高端应用中实现了业界最大带宽和最高系统集成度,非常灵活,降低了成本和总功耗。Stratix V FPGA 的优点包括高功效收发器突破了带宽,单芯片提高集成度,降低了成本,提高设计灵活性以及降低系统功耗.主要应用在100-Gb光传送网(OTN)复用转发器,100G以太网(GbE)线路,交叉矩阵和背板交换架构,军事雷达,RF卡和通道卡以及演播视频服务器.
Stratix V FPGAs are based on the high-perfo rmance architecture of Stratix IV FPGAs and deliver key architectural innovations to enable designers to achieve higher bandwidth and lower power through an unprecedented level of system integration and ultimate flexibility. These innovations include the in troduction of the Embedded HardCopy®Blocks, 28G transceivers, and partial reconfiguration. Stratix V FPGAs continue to leverage the highly successful Programmable Power Technology used in Stratix III and Stratix IV FPGAs.
查看全文
