Intersil公司的ISL8216M是简单易用的高压 DC/DC 模块, 一个封装中具备完整的开关模式电源, 广泛的输入电压范围,从10V至80V,4A 输出电流,可编程的软启动,同步和200kHz 至 600kHz 的可调节频率, 设定点精度为 ±1.5%和可编程的过流保护,主要用在服务器,48V 电信和数据通信应用,12V 和 42V 汽车和工业设备,分布式电源转换器和负载点 (POL) 调节以及通用降压 DC/DC.本文介绍了ISL8216M 主要特性,方框图,典型应用电路,以及评估板ISL8216MEVAL1Z主要特性,电路图,材料清单和PCB元件布局图.
The ISL8216M is a simple and easy to use, high voltage DC/DC module and is ideal for a wide variety of applications. It eliminates design and manufacturing risks while dramatically improving time to market.
The simplicity is in the "Off-The-Shelf" unassisted implementation. All you need is the ISL8216M, input and output capacitors, and one resistor to program the output voltage and you have a complete high voltage power design ready for the market.
The ISL8216M is packaged in a thermally enhanced, compact (15mm×15mm×3.6mm) over-molded High-Density Array (HDA) Package, which permits full load operation without heat sink or fans. The package is suitable for automated assembly by standard surface mount equipment. The small amount of external components reduce the PCB to a component layer and a simple ground layer.
ISL8216M 主要特性:
分享到:
