On Semi公司的NCN5150是用于两线M-BUS总线从设备和中继器的单片收发器,提供欧洲标准EN 13757-2和EN 1434-3的所有功能,UART通信速率高达38400波特,器件集成了3.3V VDD LDO稳压器,峰值电流15mA,可调整I/O电平,主要用在多种能源共用表, 电表,水表,气表和热力系统.本文介绍了NCN5150主要特性,框图,应用电路以及两种评估板NCN5150SOICGEVB和NCN5150QFNGEVB主要特性,电路图,材料清单和PCB布局图.
The NCN5150 is a single-chip integrated slave transceiver for use in two-wire Meter Bus (M-BUS) slave devices and repeaters. The transceiver provides all of the functions needed to satisfy the European Standards EN 13757-2 and EN 1434-3 describing the physical layer requirements for M-BUS. This particular version (NQFP version) includes a programmable power level of up to 6 unit loads, which are available for use in external circuits through a 3.3 V LDO regulator. The NCN5150 can provide communication up to the maximum M-BUS communication speed of 38,400 baud (half-duplex).
NCN5150主要特性:
• Single-chip MBUS Transceiver
• UART Communication Speeds Up to 38,400 baud
• Integrated 3.3 V VDD LDO Regulator with Extended Peak Current Capability of 15 mA
• Supports Powering Slave Device from the Bus or from External Power Supply
• Adjustable I/O Levels..
分享到:
