ST STPM10和STM8L15xx MCU单相电表解决方案
关键词:消费类电子 智能电表 MCU单相电表 STM8L15xx
时间:2013-12-23 14:03:04       作者:ST       来源:中电网
ST公司的STEVAL-IPE012V2是采用SPM10和STM8L152C6 超低功耗MCU的单相电表评估板,支持IEC 61036:1996 + A1: 2000,是低本单相电表解决方案,使用电压240V,典型电流10A,最大电流80A,电表适用频率45Hz到65Hz,动态范围200:1时的精度为1级,通信接口采用IrDA.本文介绍了评估板STEVAL-IPE012V2两个核心器件STPM10和STM8L15xx MCU主要特性,框图以及评估板STEVAL-IPE012V2主要特性和指标,电路图,材料清单和PCB元件布局图.
The STPM10 is designed for effective measurement of active, reactive and apparent energy in a power line system using current transformer and shunt sensors. The device can be implemented for peripheral measurement in a microcontroller-based single-phase or poly-phase energy meter. The STPM10 consists of two main sections: analog and digital. The analog part is composed of preamplifier and first-order sigmadelta A/D converter blocks, a band-gap voltage reference and low-drop voltage regulator. The digital part is composed of system control, oscillator, hard-wired DSP and SPI interface.
查看全文
