NXP公司的SSL2109是一款高压集成电路,在一般照明应用中,用于驱动LED 灯。该芯片是SSSL2108X 系列的扩展,但是没有内置开关器件。该芯片驱动临界导通模式降压变换器。该芯片可以通过一个内部高压电流源从HV 管脚直接启动。在启动后,从漏极处通过电容耦合的dV/dt 供电,或者任何其他辅助电源为芯片供电。这个功能在应用设计中提供了充分的灵活性。内置钳制电路用来限制供电电压。该芯片提供了高于5 % LED 电流精度的精确输出电流控制。它可以实现脉冲宽度调制(PWM)调光,并且有多重保护,包括LED 过热保护。本文首先介绍芯片的简介、特性及应用领域,并给出设计方案介绍、设计原理图、元器件列表及PCB元件布局图。
The SSL2109AT is a high-voltage Integrated Circuit (IC) for driving LED lamps in general lighting applications.
The main benefits of this IC include:
• Small Printed-Circuit Board (PCB) footprint and compact solution
• High efficiency (up to 95 %) for non-dimmable high power factor solutions
• High power factor >0.9 (application dependent)
• Ease of integration and many protection features
• Low electronic Bill Of Material (BOM)
• Highly flexible IC for use in buck, buck/boost and flyback modes
• Single inductor used for non-isolated configurations because of internal demagnetization detection and dV/dt supply
分享到:
