关键词:工业控制 工厂自动化 V850E2Mx4 32位MCU
时间:2013-11-08 10:57:39 作者:Renesas 来源:中电网
Renesas公司的V850E/2Mx4是集成了多达两个V850E2M 32位RISC CPU核的32位MCU,增强了V850E1 CPU和V850E2 CPU性能. V850E/2Mx4包括闪存,RAM和各种外设功能,可进行大容量数据处理和先进的实时控制,主要用在工业设备如工厂自动化等以及通用高性能控制设备.本文介绍了V850E2/Mx4主要特性,框图, V850E2/ML4 CPU板R0K0F4022C000BR主要特性别,系统配置图,系统框图和电路图.
The V850E2/Mx4 is a 32-bit single-chip microcontroller that integrates up to two V850E2M 32-bit RISC CPU cores, which were developed by enhancing the performance of the V850E1 CPU and V850E2 CPU. The V850E2/Mx4 includes flash memory, RAM, and various peripheral functions, and is used to perform large-capacity data processing and advanced real-time control.
V850E2/Mx4主要特性:
Power supply voltage:
Internal: 1.1 to 1.3 V
External: 3.0 to 3.6 V
Maximum operating frequency: 200 MHz ROM: 768 KB to 2 MB flash memory RAM:
V850E2/MN4
Single-core products (μPD70F3510, μPD70F3512): 64 KB
Dual-core products (μPD70F3514, μPD70F3515): 2 x 64 KB
V850E2/ML4
Single-core products (μPD70F4021, μPD70F4022): 64 KB
Packages:
V850E2/MN4: 304-pin plastic FBGA (19 x 19)
V850E2/ML4: 216-pin plastic LQFP (24 x 24) ..
分享到:
