TI TPS65580 4.5V至18V三通道同步降压转换器参考设计方案
关键词:TPS65580 降压转换器
时间:2013-10-08 10:43:00       作者:TI       来源:中电网
TI公司的TPS65580是一款先进三端输出 D-CAP2™模式同步降压转换器芯片,该芯片使系统设计工程师在完成为多种终端设备提供电源稳压器时,提供具有成本效益、低器件数量、低待机电流的解决方案。TPS65580芯片主控回路采用D-CAP2™模式控制,使得在没有外部补偿器件的情况下,提供高效快速的瞬态响应。本文首先介绍芯片的简介、特性、内部框图及应用领域,并给出相应设计方案的设计原理图及元器件列表。
The TPS65580 is a triple, advanced D-CAP2™ mode synchronous buck converter. The TPS65580 enables system designers to complete the suite of various end equipment’s power bus regulators with a cost effective, low component count, and low standby current solution. The main control loops of the TPS65580 uses the advanced D-CAP2™ mode control which provides a fast transient response with no external compensation components. The TPS65580 is able to adapt to both low equivalent series resistance (ESR) output capacitors such as POSCAP or SP-CAP, and ultra-low ESR, ceramic capacitors. The device provides convenient and efficient operation with input voltages from 4.5V to 18V.
The TPS65580 is available in 4.4mm × 6.5mm 20 pin TSSOP (PWP) package, and is specified from –40°C to 85°C ambient temperature range.
TPS65580主要特性:
Advanced D-CAP2 Control Mode
Fast Transient Response
No External Parts Required For Loop Compensation..
查看全文
