Freescale DSC 解决方案
关键词:MC56F8257 SCI通信接口 循环冗余校验
时间:2013-09-11 10:37:33       作者:Freescale       来源:中电网
Keywords:MC56F8257 , Serial Communications Interface, CRC
摘要:TWR-56F8257模块是基于MC56F8257 DSC的开发模板工具。非常适合电机控制应用,它可以与几种外设模块合并应用塔式系统,提供开发的参照。
基本特性:
The MC56F825x/MC56F824x is a member of the 56800E core-based family of digital signal controllers (DSCs). It combines, on a single chip, DSP processing power and microcontroller functionality with a flexible set of peripherals including an eFlexPWM module with NanoEdge placement as well as two ultra-fast analog-to-digital converters (ADCs), creating a cost-effective solution. Because of its low cost, configuration flexibility and compact program code, it is a perfect fit for power conversion and motor control applications, also making it well-suited for many other consumer and industrial applications.
方案简介:
The MC56F8257 Tower MCU module (TWR-56F8257) is a cost-effective evaluation, demonstration and development board. The
TWR-56F8257 can operate stand-alone or as the main control board in a Tower System with peripheral modules.
The following list summarizes the features of the TWR-56F8257:
•   Tower-compatible microcontroller module..
查看全文
