CYPRESS 的高速USB解决方案
关键词:CYUSB301X 超高速USB控制器 辅助充电器适配器
时间:2013-09-03 14:01:49       作者:CYPRESS       来源:中电网
Keywords: CYUSB301X , SuperSpeed USB Controller,ACA
摘要:Cypress的EZ-USB®FX3™开发套件(DVK)提供硬件,软件和文档,使客户能够评估FX3设备的组合。该开发套件使用FX3。赛普拉斯的软件工具和示例固件允许开发人员定制FX3设计原型,并以小时为单位研发,而不是周。
基本特性:
Universal serial bus (USB) integration
USB 3.0 and USB 2.0 peripherals compliant with USB 3.0 specification 1.0
5-Gbps USB 3.0 PHY compliant with PIPE 3.0
High-speed On-The-Go (HS-OTG) host and peripheral compliant with OTG Supplement Version 2.0
Thirty-two physical endpoints
Support for battery charging Spec 1.1 and accessory charger adaptor (ACA) detection General Programmable Interface (GPIF™ II)
Programmable 100-MHz GPIF II enables connectivity to a wide range of external devices
8-, 16-, and 32-bit data bus
As many as16 configurable control signals
方案描述:
查看全文
