Intersil ISL85415A 宽输入500mA同步降压稳压器参考设计方案
关键词:同步降压稳压器 PCB元件
时间:2013-09-02 14:10:09       作者:Intersil       来源:中电网
Intersil公司的ISL85415A是一款输入范围为3V到36V的500mA同步降压稳压调节器,为各种各样应用提供易用、高效及少量外围器件的电源解决方案。该芯片同时集成高边及低边NMOS FET场效应管。在轻载情况下,工作在PFM工作模式以最大限度提高效率,如采用PWM工作模式下PFM提高效率工作模式失效。开关频率默认为500kHz,可通过外部电阻设置开关频率为300kHz到2MHz。本文首先介绍芯片的简介、特性、内部框图及应用领域,并给出相应设计方案的设计原理图、元器件列表及PCB元件布局图。
The ISL85415A is a 500mA Synchronous buck regulator with an input range of 3V to 36V. It provides an easy to use, high efficiency low BOM count solution for a variety of applications.
The ISL85415A integrates both high-side and low-side NMOS FET’s and features a PFM mode for improved efficiency at light loads. This feature can be disabled if forced PWM mode is desired. The part switches at a default frequency of 500kHz but may also be programmed using an external resistor from 300kHz to 2MHz. The ISL85415A has the ability to utilize internal or external compensation. By integrating both NMOS devices and providing internal configuration options, minimal external components are required, reducing BOM count and complexity of design.
查看全文
