NXP高速ADC解决方案
关键词:高速ADC ADC1x13D080 JESD204A数据转换接口
时间:2013-08-27 13:53:59       作者:NXP       来源:中电网
Keywords: high speed ADC   ADC1x13D080    JESD204A data convter
摘要:恩智浦已设计了一个USB供电的演示板,演示互操作性Lattice的ECP3 FPGA的JESD204A串行接口应用恩智浦的ADC。
基本特性:
A single USB cable will allow to supply the board and to communicate with the FPGA &the ADC thanks to dedicated software running on a PC. It is then possible to load thedata from the ADC through the FPGA and have an overview of the ADC features and performance, in the frequency range of [0; 30]MHz. By default an on-board oscillator is used to generate the sampling frequency, but it is optionally possible to use an external clock to have more flexibility and a better jitter performance.
方案描述:
The list of equipment needed is as follows:
 A PC
 A USB cable
 A low jitter sine wave generator
 A band-pass filter in case the sine wave is not pure enough
 2 SMA-SMA cables if a filter is used, 1 cable if no filter
 The NXP demo board
In addition, dedicated software is necessary to drive the FPGA & the ADC from the PC.
查看全文
