ADI隔离电源控制器解决方案
关键词:隔离式PWM反馈 过流保护
时间:2013-07-29 10:35:05       来源:中电网
Keywords:Isolated PWM feedback    overcurrent protection
摘要:ADuM3070隔离器可以提供更加稳定的输出电压和更高的效率。它采用小型QSOP封装,完全集成了反馈和环路补偿,尺寸小于任何分立式解决方案。
基本特征:
ADuM30701隔离器是一款稳压DC/DC隔离电源控制器,集成内部MOSFET驱动器。该DC/DC控制器原边内置一个隔离式PWM反馈,采用iCoupler®芯片级变压器技术和完整的回路补偿。可以不必采用光耦合器进行反馈以及为了稳定性而补偿环路。
方案特点:
The EVAL-ADuM3070EBZ demonstrates two separate applications for the ADuM3070 isolated switch regulator with integrated feedback. It has two independent power supply circuits: a double supply and a single supply. The switching frequency can be set from 200 kHz to 1000 kHz. The board supports a variety of I/O configurations and multiple trans-former options. It is equipped with two ADuM3070 isolators.
Two independent and isolated circuits comprise the ADuM3070 evaluation board. The single supply is configured as a 5 V secondary isolated supply with a 5 V primary input supply, which can provide up to 2.5 W of regulated, isolated power. It can be reconfigured for a 3.3 V secondary isolated supply with a 5 V or 3.3 V primary input supply (see the Other Input and Isolated Output Supply Options section).
查看全文
