ADI ADuM4471隔离DC-DC控制器参考设计方案
关键词:ADuM4471隔离DC-DC控制器
时间:2013-07-22 11:46:57       来源:中电网
ADI公司的ADuM4471是一款内嵌MOSFET驱动器和校准器的四通道数字光电隔离DC-DC功率控制器,基于ADI先进iCoupler®技术,该控制器内部集成次边PWM光电隔离反馈补偿回路。有效减少了外部光电隔离电路和补偿回路的元器件,为实现小型化设计提供了基础。该控制器输入电压为5V或3V,输出电压范围为:3.3V-24V。单路输出功率可以达到2.5W。四通道可分别灵活独立配置,以满足用户不同的应用需要。本文介绍了DADuM4471芯片的主要特性、方框图、应用方向。评估板EVAL-ADuM5211EBZ的主要特性、电路图、材料清单和PCB元件布局图。
The ADuM4470/ADuM4471/ADuM4472/ADuM4473/ADuM44741 are quad-channel, digital isolators with a regulated dc-to-dc isolated power supply controller and an internal MOSFET driver. The dc-to-dc controller has an internal isolated PWM feedback from the secondary side, based on the iCoupler? chip scale transformer technology and complete loop compensation. This eliminates the need to use an optocoupler for feedback and compensates the loop for stability.
The ADuM447x isolators provide a more stable output voltage and higher efficiency compared to unregulated isolated dc- to-dc power supplies. The fully integrated feedback and loop compensation in a wide-body SOIC package provide a smaller form factor and 8.3 mm creepage distance solution.
查看全文
