TI ADS1299多路低噪音EEG模拟前端解决方案
关键词:医疗电子 脑电图(EEG) 心电图(ECG) AFE
时间:2012-09-13 10:26:24       作者:TI       来源:ADS1299
TI公司的ADS1299是8路低噪音同时取样的24位delta-sigma ADC,并内置了可编程增益放大器(PGA),基准电压和振荡器,集成了脑电图(EEG)所需的通用特性.器件具有非常低的输入参考噪音:1.0 μVPP (70-Hz BW),没路的功耗5mW,输入偏置电流300pA,数据速率250SPS到16kSPS,C1.0 μVPP (70-Hz BW),CMMR为-110dB,可编程增益为1, 2, 4, 6, 8, 12或24,单极或双极电源工作,主要用在医疗仪器如EEG和ECG,听觉诱发电位(EAP),脑电双频谱指数(BIS),睡眠研究监测等,高精度多路信号采集.本文介绍了ADS1299主要特性,功能框图,单电源和双极电源工作电路,以及评估板ADS1299EEG-FE主要特性,框图,电路图,材料清单和PCB布局图.
The ADS1299 is a low-noise, multichannel, simultaneous-sampling, 24-bit, delta-sigma (ΔΣ) analog-to-digital converter (ADC) with a built-in programmable gain amplifier (PGA), internal reference, and an onboard oscillator. The ADS1299 incorporates all commonly-required features for electroencephalogram (EEG) applications.
With its high levels of integration and exceptional performance, the ADS1299 enables the creation of 23scalable medical instrumentation systems at  significantly reduced size, power, and overall cost.
查看全文
