时间:2012-08-02 10:09:48 作者:Fairchild 来源:FLS3247
Fairchild公司的FLS3247是集成了功率MOSFET的单级PFC初级调整的离线LED驱动器,包括PWM控制器和功率MOSFET,能增强低功率反激转换器的性能,应用电压范围80VAC ~ 308VAC,提供LED开路,短路和超温保护功能.主要用于LED照明系统.本文介绍了FLS3247主要特性,方框图,通用输入10W LED驱动器电路图以及10W LED驱动器评估板主要指标,电路图,材料清单和PCB布局图.
This highly integrated PWM controller with power MOSFET, FLS3217 / FLS3247, provides several features to enhance the performance of low-power flyback converters. The proprietary topology enables simplified circuit design for LED lighting applications.
By using the single-stage topology with primary-side regulation, an LED lighting board can be implemented with the few external components and minimized cost; requiring no input bulk capacitor or feedback circuitry.
To implement good power factor and low THD, constant on-time control is utilized with an external capacitor connected to COMI. Precise constant-current control regulates accurate output current versus changes in input voltage and output voltage. The operating frequency is proportionally changed by the output voltage to guarantee DCM operation with higher efficiency and simple design.
分享到:
