On Semi公司的NCV8855是集成了高边负载开关的多输出电源控制器/稳压器,能满足汽车无线系统和仪表盘电源的要求. NCV8855还集成了开关电源(SMPS)降压控制器,2.5A SMPS降压稳压器和两个低压降(LDO)线性稳压器控制器,和超低静态电流的NCV861x一起能组成8输出的无线系统或仪表盘电源解决方案.器件满足ES−XW7T−1A278−AB测试脉冲G负载条件,VIN工作电压9.0V-18.0V.本文介绍了NCV8855主要特性, 应用电路/方框图, 汽车无线电系统框图以及NCV8855评估板电路图与材料清单.
The NCV8855 is a multiple output controller / regulator IC with an integrated high−side load switch. The NCV8855 addresses automotive radio system and instrument cluster power supply requirements. In addition to the high−side load switch, the NCV8855 includes a switch−mode power supply (SMPS) buck controller, a 2.5 A SMPS buck regulator and two low dropout (LDO) linear regulator controllers. The NCV8855 in combination with the ultra−low quiescent current NCV861x IC forms an eight−output automotive radio or instrument cluster power solution. The NCV8855 has an internally set switching frequency of 170 kHz, with a SYNC pin for external frequency synchronization.
分享到:
