Linear公司的LTC3787是高性能多相单输出同步升压电源转换器控制器,能驱动两个N沟功率MOSFET.输入电压4.5V-38V,输出电压高达60V,±1% 1.200V基准电压, 可编程固定频率50kHz到900kHz,静态电流135uA,主要用于工业,汽车,医疗设备和军用.本文介绍了LTC3787主要特性,方框图, 12相工作连接图以及高效2相24V,46V和48V升压转换器电路图, 4相单输出升压转换器电路图,演示板DC1411A主要性能特性,电路图,材料清单和PCB元件布局图.
The LTC3787 is a high performance PolyPhase single output synchronous boost converter controller that drives two N-channel power MOSFET stages out-of-phase. Multiphase operation reduces input and output capacitor requirements and allows the use of smaller inductors than the single-phase equivalent. Synchronous rectification increases efficiency, reduces power losses and eases thermal requirements, enabling high power boost applications.
A 4.5V to 38V input supply range encompasses a wide range of system architectures and battery chemistries. When biased from the output of the boost converter or another auxiliary supply, the LTC3787 can operate from an input supply as low as 2.5V after start-up. The operating frequency can be set for a 50kHz to 900kHz range or synchronized to an external clock using the internal PLL.
PolyPhase operation allows the LTC3787 to be configured for 2-, 3-, 4-, 6- and 12-phase operation...
分享到:
