ADI ADuCM360热电偶温度监测解决方案
关键词:工业控制 温度监测 数据采集
时间:2012-06-13 10:20:32       作者:ADI       来源:ADuCM360
ADI公司的ADuCM360是全集成的4kSPS 24位数据采集系统,集成了两个高性能多路Sigma-Delta (Σ-Δ) ADC,32位ARM Cortex M3®MCU和闪存/EE存储器,能直接双线和外接精密传感器接口,并采用电池供电.模拟输入/输出,单端和全差分输入,输入范围±6.64 mV 到±1.2 V,可编程ADC输出速率(4Hz到4kHz),可编程增益从1到128,RMS噪音为43nV @3.75Hz和180nV @ 50Hz,主要用于工业自动化和过程控制,智能的精密检测系统,4mA到20mA回路智能传感器系统,医疗设备和病人监护.本文介绍了ADuCM360主要特性,方框图,以及采用ADuCM360和外接热电偶的基于USB温度监测器特性,电路图和材料清单与PCB布局图.
The ADuCM360 is a fully integrated, 4 kSPS, 24-bit data acqui-sition system incorporating dual, high performance multi-channel sigma-delta (Σ-Δ) analog-to-digital converters (ADCs), 32-bit ARM Cortex M3®MCU, and Flash/EE memory on a single chip. The part is designed for direct interfacing to external precision sensors in both wired and battery powered applications.
The ADuCM361 contains all the features of the ADuCM360 except the primary ADC, ADC0 is not available – only the auxiliary ADC, ADC1 is available.
查看全文
