Intersil ISL70001SEH 辐射加固FPGA电源解决方案
关键词:电源管理 DC/DC转换器
时间:2012-06-05 10:21:31       作者:Intersil        来源:ISL70001SEH
Intersil 公司的ISL70001SEH是集成了MOSFET的辐射和SEE加固的高效同步降压稳压器,输入电压3V到5.5V,输出电压从0.8V到输入电压的 ~85%,TJ ≤ +150℃时的输出负载电流6A,效率大于90%,开关频率1MHz或500kHz,辐射剂量为100 krad(Si),SEL和SEB LETTH 为86.4MeV/mg/cm2,主要用在FPGA, CPLD, DSP, CPU Core 和I/O电源,低压大容量分布电源.本文介绍了ISL70001SEH主要特性,方框图,主/从模式典型应用电路,以及辐射加固FPGA电源参考设计和VIRTEX5MEZPWREV1Z 评估板框图,电路图,材料清单和PCB布局图.
Rad Hard and SEE Hard 6A Synchronous Buck Regulator ISL70001SEH
The ISL70001SEH is a radiation hardened and SEE hardened high efficiency monolithic synchronous buck regulator with integrated MOSFETs. This single chip power solution operates over an input voltage range of 3V to 5.5V and provides a tightly regulated output voltage that is externally adjustable from 0.8V to ~85% of the input voltage. Output load current capacity is 6A for TJ < +145℃.
High integration and class leading radiation tolerance makes the ISL70001SEH an ideal choice to power many of today’s small form factor applications. Two devices can be synchronized to provide a complete power solution for large scale digital ICs, like field programmable gate arrays (FPGAs), that require separate core and I/O voltages.
ISL70001SEH主要特性:
查看全文
