TI 公司的bq5101x是用于手提设备的无线电源传输的接收器,提供AC/DC电源转换,同时集成了和Qi v1.0通信协议兼容的数字控制,和bq500210发送器控制器一起,能组成完整的无接触电源传输系统,AC/DC的效率93%,最大输入电压20V,主要用于WPC兼容的接收器,手机和智能手机,数码相机,手持媒体播放器和手持设备.本文介绍了bq5101x主要特性,简化框图,无线电源(WPC或Qi)的电感电源系统框图,应用电路以及bq51013AEVM-764无线电源接收器评估板主要特性和性能指标,电路图,材料清单和PCB元件布局图.
The bq5101x is an advanced, integrated, receiver IC for wireless power transfer in portable applications. The device provides the AC/DC power conversion while integrating the digital control required to comply with the Qi v1.0 communication protocol. Together with the bq500210 transmitter controller, the bq5101x enables a complete contact-less power transfer system for a wireless power supply solution. By using near-field inductive power transfer, the receiver coil embedded in the portable device receives the power transmitted by the transmitter coil via mutually coupled inductors. The AC signal from the receiver coil is then rectified and regulated to be used as a power supply for down-system electronics. Global feedback is established from the secondary to the transmitter in order to stabilize the power transfer process via back-scatter modulation.
bq5101x主要特性:
分享到:
