Infineon ICLS8082G带PFC和调光的离线LED控制方案
关键词:电源管理 LED驱动器 AC/DC转换器 PFC
时间:2012-03-15 11:20:52       作者:Infineon       来源:ICLS8082G
Infineon公司的 ICLS8082G是集成了800 V CoolMOS®带PFC和调光的离线LED控制器,功率因速大于98%,和其它通用的解决方案相比,效率有大幅度提高,器件工作电压高达26V,功耗低.并具有多种安全保障.主要用在100W / 60W / 40W 白炽灯泡替代,LED灯管等. 本文介绍了ICLS8082G产品亮点和主要特性,方框图,典型应用电路以及评估板EVAL-LED-ICLS8082G-B2主要特性和指标,电路图,材料清单,变压器设计图与PCB元件布局图.
Offline LED Controller For PFC And Dimming With Integrated 800 V CoolMOS®
The ICLS8082G employs a quasi-resonant operation mode optimized for off-line LED lighting, especially for dimmable LED bulbs for replacement of incandescent lamps.
Precise PWM generation enables primary control for phase-cut dimming and high power factors (PF) > 98 %. It offers significantly improved driver efficiency, up to 90 %, compared to other conventional solutions. The product has a wide operation range (up to 26 V) of IC voltage supply and lower power consumption. Multiple safety functions ensure full system protection in failure situations.
With its full feature set and simple application, the ICLS8082G represents an outstanding choice for quasiresonant flyback LED bulb designs combining the feature set and performance at minimum BOM cost.
ICLS8082G产品亮点:
查看全文
