Renesas公司的 SH7216系列是32位SH-2A RISC CPU核的微控制器,最大工作频率200MHz,具有400 MIPS新能,集成了大容量高速闪存和RAM以及电源降压电路,PWM定时器,12位ADC,LAN控制器,USB和CAN外设。工作电压3.3V,主要用在工业设备包括PLC,AC伺服系统和通用逆变器等。本文介绍了SH7216主要特性及其开发板目标应用和主要特性,方框图,和PC连接图与详细电路图。
The SH7216 Series with 32-bit SH-2A CPU core offers a maximum operating frequency of 200 MHz, representing a 1.25-fold improvement in performance over the 160 MHz of Renesas Electronics’s existing the SH7211. They also include large-capacity high-speed flash memory and RAM through the use of cutting-edge flash memory technology. Featuring an on-chip power supply step-down circuit, these microcontrollers are designed to achieve lower current dissipation by suppressing the increase in current dissipation associated with higher speed, and attain 3.3 V single-power-supply operation while at the high operating frequency of 200 MHz. In addition, the SH7216 Series incorporates a PWM timer, 12-bit AD converter, LAN controller, USB, and CAN as peripheral functions.
The SH7216 Series lineup consists of the SH7216 Group (with floating-point unit (FPU)) and the SH7214 Group (without FPU).
SH7216主要特性:
High-performance single-chip RISC with SH-2A core
分享到:
