Linear LT8582故障保护双路PWM DC电源解决方案
关键词:电源管理 DC/DC转换器 PWM SEPIC
时间:2012-02-01 11:17:27       作者:Linear       来源:LT8582
Linear公司的LT8582是带故障保护的双路独立的PWM DC/DC转换器,每路包括42V主开关和42V从开关,并联使用的总电流为3A,具有过压,超温以及输出短路保护.工作电压2.5V-22V,开关频率高达2.5MHz,每路可容易配置成升压,SEPIC,反向或反激转换器,主要用在本地电源,VFD偏压电源,TFT-LCD偏压电源和汽车引擎控制单元(ECU)电源.本文介绍了LT8582主要特性,方框图,基本应用电路以及多种典型应用电路与两种拓扑的元件布局图.
The LT8582 is a dual independent channel PWM DC/DC converter with a power good pin and built-in fault protection to help guard against input overvoltage and overtemperature conditions. Each channel consists of a 42V master switch and a 42V slave switch that can be tied together for a total current limit of 3A.
The LT8582 is ideal for many local power supply designs. Each channel can be easily configured in boost, SEPIC, inverting, or flyback configurations. Together, the two channels can produce a 12V and a –12V output with 14.4W of combined output power from a 5V input. In addition, the LT8582’s slave switch allows the part to be configured in high voltage, high power charge pump topologies that are more efficient and require fewer components than traditional circuits.
查看全文
