ST STEVAL-ISA018V1 150W开关电源解决方案
关键词:电源管理AC/DC转换器
时间:2011-12-30 09:06:33      来源:STEVAL-ISA018V1
ST公司的STEVAL-ISA018V1评估板是150W开关电源解决方案,采用高压谐振控制器L6599,输入电压是185V-265VAC或85V-185VAC,输出电压24V+/-2%,输出功率150W,峰值功率240W,安全性满足EN60950,EMI满足EN55014.本文介绍了L6599主要特性,方框图, 采用L6599和L6563 90W适配器电路图以及STEVAL-ISA018V1评估板主要特性,电路图和材料清单.
The L6599 is a double-ended controller specific for the resonant half-bridge topology. It provides 50 % complementary duty cycle: the high-side switch and the low-side switch are driven ONOFF 180° out-of-phase for exactly the same time.
Output voltage regulation is obtained by modulating the operating frequency. A fixed deadtime inserted between the turn-OFF of one switch and the turn-ON of the other one guarantees soft-switching and enables high-frequency operation.
To drive the high-side switch with the bootstrap approach, the IC incorporates a high-voltage floating structure able to withstand more than 600 V with a synchronous-driven high-voltage DMOS that replaces the external fast-recovery bootstrap diode.
The IC enables the designer to set the operating frequency range of the converter by means of an externally programmable oscillator.
At start-up, to prevent uncontrolled inrush current, the switching frequency starts from a programmable maximum value and progressively decays until it reaches the steady-state value determined by the control loop. This frequency shift is non linear to minimize output voltage overshoots; its duration is programmable as well.
The IC can be forced to enter a controlled burst-mode operation at light load, so as to keep converter’s input consumption to a minimum.
IC’s functions include a not-latched active-low disable input with current hysteresis useful for power sequencing or for brownout protection, a current sense input for OCP with frequency shift and delayed shutdown with automatic restart.
A higher level OCP latches off the IC if the first-level protection is not sufficient to control the primary curr...
  • 主 题:人形机器人中的电源供应方案介绍
  • 时 间:2026年6月15日
  • 公 司:Texas Instruments
