关键词:电源管理 LED驱动器 AC/DC转换器 PSR PWM
时间:2011-11-30 09:44:39 作者:Fairchild 来源:FSEZ1317NY
Fairchild公司的FSEZ1317NY是第三代初级边调整(PSR)和高度集成PWM控制器,待机功耗低于300mW,高压起动,具有最少的外接元件,没有次级反馈电路的恒压(CV)和恒流(CC)控制,PWM固定频率50kHz,主要用在手机,无绳电话,PDA,数码相机等充电器,替代线性变压器和RCC开关电源(SMPS).本文介绍了FSEZ1317主要特性, 功能方框图, 简化PSR反激转换器电路图, 高压起动电路图和6W LED照明驱动器主要特性,电路图和变压器电路图.
FSEZ1317: Primary-Side-Regulation PWM with POWER MOSFET Integrated
This third-generation Primary-Side-Regulation (PSR) and highly integrated PWM controller provides several features to enhance the performance of low-power flyback converters. The proprietary topology, TRUECURRENT™, of FSEZ1317 enables precise CC regulation and simplified circuit design for batterycharger applications. A low-cost, smaller, and lighter charger results, as compared to a conventional design or a linear transformer.
To minimize standby power consumption, the proprietary green mode provides off-time modulation to linearly decrease PWM frequency under light-load conditions. Green mode assists the power supply in meeting power conservation requirements.
By using the FSEZ1317, a charger can be implemented with few external components and minimized cost.
FSEZ1317主要特性:
Low Standby Power Under 30mW
分享到:
