关键词:通信技术 有线通信 动力线通信 PLC 模拟前端 AFE
时间:2011-10-20 11:57:07 作者:TI 来源:AFE031
TI 公司的AFE031是低成本高集成的动力线通信(PLC)模拟前端,可采用电容或变压器和动力线进行连接. AFE031具有热保护和过流保护,和EN50065-1兼容,15V电源和1.5A时的输出摆幅12Vpp,接收模式的功耗15mW,支持EN50065 CENELEC Bands A, B, C, D,以及FSK, S-FSK与OFDM和PRIME, G3, IEC 61334,接收器灵敏度20uV,可编程Tx/Rx增益控制,采用四线串行接口.主要用在eMetering,照明,太阳能和控制线.本文介绍了AFE031主要特性, 方框图, 动力线通信系统框图, 动力线通信调制解调器,相关电路以及开发套件TMDSPLCKIT-V3主要特性, 窄带PLC解决方案框图, 智能电网到家的PLC解决方案框图和plcSUITE软件架构图, TMDSPLCKIT-V3 PLC开发板PCB布局图.
The AFE031 is a low-cost, integrated, powerline communications (PLC) analog front-end (AFE) device that is capable of capacitive- or transformer-coupled connections to the powerline while under the control of a DSP or microcontroller. It is ideal for driving low-impedance lines that require up to 1.5 A into reactive loads. The integrated receiver is able to detect signals down to 20 µVRMS and is capable of a wide range of gain options to adapt to varying input signal conditions. This monolithic integrated circuit provides high reliability in demanding powerline communications applications.
分享到:
