时间:2011-09-07 14:35:47 作者:Radiocrafts 来源:RC1180-KNX
Radiocrafts公司的RC1180-KNX是表面安装的高性能发送模块,它的尺寸仅为12.7 x 25.4 x 3.3 mm,能很容易集成在传感器或激励器中,采用UART接口作为串行通信和配置,天线直接连接到RF引脚,适合欧洲标准(CENELEC EN 50090和CEN EN 13321-1),国际标准(ISO/IEC 14543-3),中国标准(GB/Z 20965)以及美国标准(ANSI/ASHRAE 135).工作频率868.0 – 870.0 MHz,工作电压2.0 – 3.9 V,并具有超低功耗,主要应用在家庭和建筑物控制,HVAC,AMR和自动读表以及网关等.本文介绍了RC1180-KNX主要特性, 典型连接图, 应用示意图以及三种RCxxxxDK-USB演示板方框图,电路图,材料清单以及PCB元件布局图.
The RC1180-KNX® RF Transceiver Module is a compact surface-mounted high performance module with embedded KNX-RF Multi protocol as defined by the KNX Association (www.knx.org). The module has a UART interface for serial communication and configuration. The module is pre-certified for operation under the European radio regulations for license-free use and measures only 12.7 x 25.4 x 3.3 mm with shielding. When used with quarter-wave antennas a line-of-sight range of 600-800 meter can be achieved. The RC1180-KNX meets the KNX specification and supports S, A and E modes, and operates in the 868 MHz frequency band. The physical layer complies with the relevant parts of the EN 50090 (ISO/IEC 14543-3).
RC1180-KNX主要特性:
Embedded KNX-RF protocol (KNX-RF v1.1, KNX Ready and KNX-RF Multi)
分享到:
