关键词:消费类电子 D类放大器;汽车电子 汽车音响 汽车娱乐系统
时间:2011-09-01 09:45:11 作者:NXP 来源:TDF8599C
NXP公司的TDF8599C是I2C总线控制的立体声双BTL汽车D类音频放大器,包括采用SOI BCDMOS技术的SOI BCDMOS输出级,能向8欧姆提供136W的功率,并具有全诊断功能。器件的工作电压从8V到48V,具有低静态电流和高效率,主要用在汽车音响和汽车娱乐系统。本文介绍了TDF8599C主要特性和优势,方框图,输出滤波器电路图以及几种典型应用案例电路图。
The TDF8599C is a dual Bridge-Tied Load (BTL) car audio amplifier comprising an NDMOST-NDMOST output stage based on SOI BCDMOS technology. Low power dissipation enables the TDF8599C high-efficiency, class-D amplifier to be used with a smaller heat sink than those normally used with standard class-AB amplifiers.
The TDF8599C can operate in either non-I2C-bus mode or I2C-bus mode. When in I2C-bus mode, DC load detection results and fault conditions can be easily read back from the device. Up to 15 I2C-bus addresses can be selected depending on the value of the external resistors connected to pins ADS and MOD.
When pin ADS is short circuited to ground, the TDF8599C operates in non-I2C-bus mode. Switching between Operating mode and Mute mode in non-I2C-bus mode is only possible using pins EN and SEL_MUTE.
TDF8599C主要特性和优势:
High-efficiency
Low quiescent current
Operating voltage from 8 V to 48 V
分享到:
