ADI AD9122高速DAC和ADL5373 I-Q调制器接口解决方案
关键词:通信技术无线通信 W-CDMA CDMA2000 TD-SCDMA WiMAX GSM LTE
时间:2011-8-29 10:44:26      来源:AD9122
ADI公司的AD9122是双路高动态范围的高速DAC,取样速率1230MSPS,灵活的LVDS接口, 122.88 MHz IF的单载波WCDMA ACLR为82dBc, RL = 25 Ω to 50 Ω时的模拟输出从8.7 mA 到31.7 mA可调,集成了2x/4x/8x内插/复数调制器,使得载波可放置在DAC带宽内任何地方, 1.2 GSPS的功率为1.5W, 500 MSPS的功耗为800mW,主要用在无线基础设备, W-CDMA, CDMA2000, TD-SCDMA, WiMAX, GSM, LTE和宽带通信如LMDS/MMDS,点对点通信,数字高或低IF合成.本文介绍
ADI公司的AD9122是双路高动态范围的高速DAC,取样速率1230MSPS,灵活的LVDS接口, 122.88 MHz IF的单载波WCDMA ACLR为82dBc, RL = 25 Ω to 50 Ω时的模拟输出从8.7 mA 到31.7 mA可调,集成了2x/4x/8x内插/复数调制器,使得载波可放置在DAC带宽内任何地方, 1.2 GSPS的功率为1.5W, 500 MSPS的功耗为800mW,主要用在无线基础设备, W-CDMA, CDMA2000, TD-SCDMA, WiMAX, GSM, LTE和宽带通信如LMDS/MMDS,点对点通信,数字高或低IF合成.本文介绍了AD9122主要特性, 功能方框图, AD9122评估板以及AD9122高速DAC和ADL5373 I-Q调制器接口解决方案,包括接口电路, AD9122-M5375-EBZ评估板电路图和材料清单.
Interfacing the ADL5375 I/Q Modulator to the AD9122 Dual Channel, 1.2 GSPS High Speed DAC
The AD9122 is a dual, 16-bit, high dynamic range digital-to- analog converter (DAC) that provides a sample rate of 1230 MSPS, permitting multicarrier generation up to the Nyquist frequency.
The AD9122 TxDAC+® includes features optimized for direct conversion transmit applications, including complex digital mod- ulation, and gain and offset compensation. The DAC outputs are optimized to interface seamlessly with analog quadrature modulators, such as the ADL537x F-MOD series from Analog Devices, Inc. A 4-wire serial port interface provides for program- ming/readback of many internal parameters. Full-scale output current can be programmed over a range of 8.7 mA to 31.7 mA. The AD9122 comes in a 72-lead LFCSP.
PRODUCT HIGHLIGHTS
1. Ultralow noise and intermodulation distortion (IMD) enable high quality synthesis of wideband signals from baseband to high intermediate frequencies (IF).
2. Proprietary DAC output switching technique enhances dynamic performance.
3. Current outputs are easily configured for various single- ended or differential circuit topologies.
4. Flexible LVDS digital interface allows the standard 32-wire bus to be reduced to one-half or one-quarter of the width.
AD9122主要特性:
Flexible LVDS interface allows word, byte, or nibble load
Single-carrier W-CDMA ACLR = 82 dBc at 122.88 MHz IF ...
  • 时 间:2026年5月19日
  • 时 间:2026年6月4日
  • 公 司:Arrow&NXP&murata
