关键词:工业控制 建筑物自动化;医疗电子 心电图(ECG) 生命信息监测仪
时间:2011-08-12 10:47:45 作者:Freescale 来源:Kinetis
Freescale 公司的Kinetis K60系列是低功耗MCU,工作电压1.71-3.6V,闪存的写电压为1.71-3.6V,采用高达100MHz的ARMRCortex™-M4内核,其性能可达到1.25 Dhrystone MIPS per MHz,同时可选择浮点单元, IEEE 1588以太网,USB 2.0 OTG,加密和篡改检测,具有极好的性能,环境温度为-40 到105°C,主要用在工业如安全照相机, 建筑物自动化控制和电梯控制屏以及医疗电子如心电图(ECG),生命信息监测仪,运程医疗保健系统,心率监视器, 除颤仪, 麻醉监视器, 呼吸机等.本文介绍了K60系列主要特性,方框图, TWR-K60N512-KIT K60系列开发套件主要特性,方框图和电路图.
Kinetis K60: Low-Power MCU with optional Floating Point Unit, Ethernet, USB, Encryption and Tamper Detect
Kinetis is the most scalable portfolio of low power, mixedsignal ARMRCortex™-M4 MCUs in the industry. Phase 1 of the portfolio consists of five MCU families with over 200 pin-,peripheral- and software-compatible devices. Each family offers excellent performance, memory and feature scalability with common peripherals, memory maps, and packages providing easy migration both within and between families.
分享到:
