TI公司的CC110L是低成本的小于1GHz(300 - 348 MHz,387 - 464 MHz和779 - 928 MHz)的RF收发器,两个CC110L收发器可构成低成本的双向RF链接.RF收发器集成了高度可配置的基带调制解调器,支持各种调制格式(2-FSK, 4-FSK, GFSK和OOK),数据速率从0.6 到600 kbps可编程,输出功率可编程,高达+12dBm,在0.6kbps时的接收灵敏度为-116dBm,主要用在无线告警和安全系统,工业监视和控制,遥控,玩具, 家庭和建筑物自动化灯.本文介绍了CC110L主要特性, 简化方框图, 典型应用和315/433MHz和868/915MHz评估电路图与材料清单, CC110LEM 868/915 MHz参考设计和电路图,材料清单,以及CC11xLDK-868-915开发板主要特性,电路图.
The CC110L is a cost optimized sub-1 GHz RF transceiver for the 300 - 348 MHz,387 - 464 MHz, and 779 - 928 MHz frequency bands. The circuit is based on the popular CC1101 RF transceiver, and RF performance characteristics are identical. Two CC110L transceivers together enable a low cost bidirectional RF link.
The RF transceiver is integrated with a highly configurable baseband modem. The modem supports various modulation formats and has a configurable data rate up to 600 kbps.
CC110L provides extensive hardware support for packet handling, data buffering and burst transmissions.
分享到:
